LCR
Since your saying you were having problems with your battery and/or charging system I would def get that checked out before you start taking engine covers off.
Subscribed to hear the result. I'm putting my money on a stator issue.
Kenny,
This procedure does say oil so it looks like you have to dump the oil. The plug is #1 and the crankshaft position sensor is #5 The rotor is #6.
Hope your oil change is near due.
See attached.
I had a charging system/battery issue last May, after changing the battery the problem was fixed. But once again, after 4-5 months with a new battery, I am having charging/battery issue again. This is why I am thinking that there is something wrong with my charging system. Someone had mentioned that it was the voltage regulator. I jumped started my bike with a car with it's motor running and somebody said that that was very bad thing to do.
If it's a failing charging system, this could lead to my failed crankshaft posisiton sensor.
I'm pissed off on hearing that, I just swapped out my oil and filter last week. Not even 200 miles on the clock with the new change. I put the good oil in too, the Castrol 12.99 per quart.
Hopefully, it's just a loose wire or disconnecting the battery will reset everything.
Otherwise, I think this this is going to the repair shop, this repair sounds like it's getting too technical. Mechanically, I suck. Period.
To clairify things, are you saying not to take off the Cranking Sensor Cover until the oil is drained?
The reason you can damage your regulator/rectifier when you jump the bike from a car is if the car is running, the regulator on the bike sees it's threshold voltage provided from the car charging system and because bike uses a shunt type regulator it passes additional current through a solid state device that is coupled to a heat sink and dissipates the additional current as heat. Since a cars charging system provides much more current than the bike's regulator/rectifier can dissipate, the bike's regulator can be damaged.
You can jump start from a car but the car must not have the engine running.
Yes he needs to have a working battery and charging system.
Too bad there isn't a bike being parted out.
Looks like I'll be a cruiser dude for a while. Everybody is telling me that I don't look the part (riding in full gear). I want to look like a pro, not a poser.
So my gameplan is to change out the voltage regulator and stator first, or are they the same? What part number would that be on Ron Meyers? I want to make sure I order the correct.
I might try disconnecting the battery and see if I can get the error code to dissapear. But I am not going to go near the Crankshaft Sensor unitl the charging system is swapped out.
Thanks everyone,
I ended up taking the 1600 Roadster Cruiser after I got the bike home. I stopped to get fuel because the fuel light was on, find out I didn't receive the fuel key. Now I'll probably run out fuel on the way back home.
Not a good day.
The current battery installed which is about 4-5 months old has never been subjected to a jump start. It has been the previous battery(s) that were jump started. Which makes me to believe why would a new battery would go south so quickly?
I have the day off tommorow, I should be able to trouble shoot a lot of the things that everyone has suggested then.
Once again, thanks everyone!
Update: Battery disconnected for 30 minutes, and after connecting still gives me an error code 12.
Ontop of the baterry, I had written in the install date with mileage. 5/28/11, and the current mileage makes it at 9,000 miles.
I am going to Cycle Gear and get a new battery. They will replace it for free if my battery cannot hold a charge. I had it on the tender for the past two days so it will have a full charge I'm presuming, how are they going to determine if it's bad?
