Silvia6
^^ Cliff, good eye and good observation. Is it possible the ECM throws a fault due to the engine being under temp? Sounds unlikely but :don'tknow::don'tknow:
Silvia,
Any chance you have a DMM? I'm curious what the battery voltage is at idle and above 8000?
So, without a load, it Revved to 9000 but with a load i.e. riding it, it fails to accelerate, but keeps running as you keep it above 8000.
What does it really do during this time? Is it missing, sputtering, how does the tone sound? Anything to give us some insight about its running when it fails to accelerate would be helpful. This is STRANGE!!!
If there were NO WARNING light but it failed to Rev above 8k I'd be normally looking at some of the following:
Fuel delivery, i.e. loss of pressure/volume for the demand
Spark energy, i.e. do this at night in pitch black and look for high voltage arc-over from spark plug wires, either from ground or to each other.
Because its so RPM dependent; I still wonder about the crank trigger.
- I measured the battery a few weeks ago (when I replaced it) in idle speed and when accelerating (but not over 8000 rpm, I measured it at 5-6000 rpm) and the voltage was right (I don't remember the precise values but ~14.4 V when accelerating and ~13.4 in idle speed).
-Actually, (as far as I could notice with my very noisy helmet) there is no strange sound, no signs to warn me that there is something wrong and if it weren't for that light I probably wouldn't have noticed anything. Tomorrow, before work, I will take a ride on the highway (I live in a very crowded city and there's no way I can reach 8000 rpm in the city), I will test it again but this time paying more attention to what you have pointed out. I will also test it in all gears, to see if the warning light appears exactly the same in all gears (I first noticed the problem when I was in the 6th gear at ~110 mph/170kmh). I am very curious about what happens if I don't turn off the acceleration and I keep riding at >8000 rpm with the warning light on (in terms of sounds, or motorcycle behavior), but I don't want to do any damage to my beloved motorcycle.
-The spark plugs are new and according to the manual: cr9ek (normal, not iridium). When I replaced the old ones I saw that the previous owner had used cr9e spark plugs, not cr9ek (thing which, after seeing the spark plugs, I thought caused the warning light - but it didn't). I don't know how to perform the operation that you described, with the spark energy, but I will do some research to see what I have to do and how to do it.
- The loss of loss of pressure/volume for the demand seems to be a good point and something that can cause this, as well as the crank trigger. I'll look into that.
Also, there is a question that keeps coming to my mind: do you think it is possible that this problem is related to the injectors?
The situation is very strange indeed. And extremely annoying, as I can't really put my finger on it. I'll keep you guys posted as I make more progress with the investigation.
Thank you again so much for the support and great ideas!
