Engine smokes badly
dimi4able
Latvia
Help. Guys i just bought FZ 6 2006. when i warm up engine it starts to smoke badly, blue smokes and some oil spitting from pipes... i understand that the situation is ****ty but maybe you could give me some advise(tips). what to do now,were from should i start, and what could be the problem:confused:
sorry for my english lads
Pull the spark plugs and inspect. One or more will be black and NOT a normal tan.
A compression tester will give you an idea on the basic condition and what specific cylinder is bad.
A leak down tester is MUCH MORE accurate and can help pinpoint down what/where the issue is. This is the unit I use;
Cylinder Leakage Tester Kit | OTC Tools
It doesn't sound good at all, I hope you got a REALLY GOOD DEAL as your likely putting a new engine in it..
I'm assuming you still have a locking gas cap on it? Make sure the fuel is fresh in it, perhaps some Seafoam may help (stuck rings) but its probably more serious than that. Check the oil as well, probably change it as well with a filter..
