- Joined
- Mar 23, 2012
- Messages
- 1,604
- Reaction score
- 845
- Points
- 113
- Location
- Northern New Joizey
I want to tinker with the CO adjustment on my 05, but I cannot get into adjustment mode. I am thinking the FSM has an error or omission. Mine says to hold SELECT and RESET pressed while turning key on. When I do that, I go to DIAG mode, which jives with the manual. However, pressing SELECT should change to CO mode, but it does not. I can hold SELECT and RESET to select DIAG, then I can scroll through different tests.
Elsewhere in the manual, it says to disconnect the lead to the fuel pump, but that seems to be for DIAG mode.
I have not tried disconnecting the pump, and I recall somewhere that some models require a jumper in the wiring harness, but I thought tht was on the S2.
Also, what does "Be sure to set the CO density level to standard,and then adjust the exhaust gas volume." mean? I see nothing in the FSM about that setting.
Anyone know what I am doing wrong?
