clutch friction zone?
studerman1
Iowa
Is it just a fz6 thing that the clutch engages at the very end. I would prefer it being in the middle any way to change it?
Isn't that what the killernoodle mod does? I haven't done it, but a ton of positive reviews on here.
Nope, the KN mod (when available), simply moves the cable out farther (with the lower "lever").
That simply makes the friction zone wider, it does not bring the lever closer. If anything, with the wider friction zone, it
would make it harder (less room) to play with the cable adjustment
The zone is tight stock BUT, once used to it, faster, clutch shifts are possible..
agf
Go Naked- Its liberating
Melbourne Australia
I have the KN clutch mod , I did it for smoother take offs in 1st with the missus on pillion - I was well used to the short friction zone riding solo- i reckon the blunt take off is great! I dont think i could go back to a sloppy clutch
Scott is spot on about the lever to grip distance you can get some variation withcable adhustment but variable levers like pazzos is the most versatile way to change grip/ lever distance with a properly adjusted clutch cable
