philz
Hi all
After fitting my 2wheels levers I found that the bite was quite far out so I adjusted the cable (via the adjuster dial) which made the bite much closer how I like it but now the lever seems to be loose (ie it doesn't spring back out properly)
If I adjust the adjuster back so that the lever springs back ok, then my bite is far out too.
Does anyone have any tips for how to get my lever to be fully out when not engaged but to also have the bite close to the grip? There must be some trick in the procedure that I'm just not doing (something at the engine end I'm guessing)
