Chain lube stained my wheel
autobahn70
Fairport, New York
I lubed my chain using Blue Label chain lube and the stuff got all over the back wheel. Now i have spots from it that dont come off with soap and water. Does anybody know a remedy for this that wont ruin the finish? Im assuming its happened to other people. Thanks a lot
Yamaha makes a mud, grease and engine cleaner you can use; part number ACC-MUDGR-CL-NR; will not harm plastic, rubber or metal parts. I bought a can at the local bike shop for $4.99. WD-40 & Goo Off work well and can be found locally.
Keep riding until you have to replace the tire, then the stains will be gone! :rockon:
+1 on Simple Green. If that doesn't work, WD40 should!
I used WD40 and a rag on the underside of the rear hugger and it got off all the road grime easily. WD40 shouldn't harm painted surfaces as long as you wash it off.
