Center Stand Removal
Doorag
West London
www.4dbrown.com
Q for anyone who has actually removed their centre stand :-
On the right side of the bike it looks like the center stand bracket holds a few other brackets. Do I need to keep all the bolts on that side mounted or can I just remove all the stuff over there?
The left side is straight forward since it's just two bolts.
Thanks!
I never removed mine but when I bought it the po had removed it and I reinstalled it. It seemed very easy as I remember and I do not wrench. In your case just remove a couple bolts and a spring and it comes right off. My only hiccup was putting the spring back on but as I said it should be pretty clear cut.
I would remove the stand and then put the bolts back anyway so that you know where they are if you ever want to put the stand back on.
I just bought my FZ6 and found that it came without a center stand. I bought one, but can't figure out how to install it. Can somebody post a picture of their bike so I can figure out how it installs?
