Circuitrider
I am installing a fuse box today and want to use a relay to keep all accessories that will eventually go into that box switched.
I have a Bosch 5 pin relay and I'm not sure what goes where. I know I have to use ground, hot from battery, but I'm not sure if I take a positive or negative from (e.g. horn) to be switched and what pin it goes to.
85 (???) What goes here? Switched wire? +, -, ?
86 ground out to fuse block
87a (???) What goes here?
87Hot in from battery
30Hot out to fuse block
Can you check this and help me make sure I do this right?
Thanks!
Matthew
Thanks!
Matthew
