sleepymas
cool thanks for the description on how it works, i can see where some very small gains and taking away the pop can come now but minimal is what i would assume, but every little bit helps if it makes a rider more confident!!
n00b question, how do I do this?
The AIS on our bikes has no air pump, it relies on vacuum in the exhaust port to draw air in vs. vorced air by a pump. The goal of the system is similar to cars though...provide excess-air so that any unburned fuel in the exhaust stream is burned esp. at cold start or idle. This is good for emissions and also good for the health of the catalytic converter.
I'm not sure how removing the system is going to make any performance gains. Granted on a race bike it eliminates some weight and components and there may be some thermal advantages. I suppose that by removing it you'll be affecting what the O2 sensor sees at certain conditions, which may cause a fuel trim shift on 2007+ bikes. It is probable that the O2 sensor is ignored when AIS is commanded active though...so maybe no change there.
I don't think it does a test (like downstream O2 monitoring) other than a continuity check on the solenoid. That is more of a OBD2 requirement for cars.
*EDIT* I reviewed the error code table for a 2007, and do not see one listed for AIS solenoid. So, it may be possible to simply disconnnect it if you are so inclined and not see a fault code.
There is only an output test listed:
48 AI system solenoid
Actuates the AI system solenoid
for five times every second.
Illuminates the engine trouble
warning light.
Check the operating sound
of the AI system solenoid
five times.
