2004 Fz6 clutch
Patrick1714
Ontario
Hey I just recently picked up myself a 2004 Fz6, does anyone know if parts up to 2010 are interchangeable? I also just want to know if anyone knows how to reduce the force needed to pull into the clutch, I read that the MT-07 push lever, part 1WS-16340-00 may help, but i am not sure if it will fit. If you guys have any suggestions that would be amazing!
K
kristoffersmith
I changed the pulling angle the arm. I let some cable out and moved it a little past 90º so that I had more leverage as I got into the clutch pull
Yamaha part # 1WS-15340-00 is the engine mounted (by the clutch) lever that's a bit longer and will fit the FZ..
It'll reduce the pull maybe 30% (approx), but you'll definitly feel it...
Pay close attention when swapping the lever to make sure it's "clocked" properly...
