Because I found that the position in the first picture is shortened, maybe it is the cause of clutch slippage?
I use a torque wrench to fix the six screws of the clutch. The conversion data in the manual is 81.6kgf.cm. I use 85 for fixing.
If you think the lever on the clutch is difficult to fix, please relax the spring first and loosen all the clutch clearance screws. There is an adjustment position on the left handle and under the left fuel tank and air filter. There are currently no video tutorials on the Internet. Describe this item
This is the license plate frame of R1, and the ring blinker. I will change the red to yellow later because it is not conspicuous enough.
The parts currently used are all from China
direction light
R1 License plate frame
R6/FZ6 gasoline pump
Clutch plate
Gasket
I can guess what the problem is. When first gear enters second gear, there is a chance to enter neutral, and the power cut I feel in second gear should be because "the engine is running in second gear, causing the gear to jump back to neutral and then jump back to second"
