Nix
Hello,
I recently decided to do a scrambler conversion on my 04 FZ6 and purchased a new headlight.
https://speedmotoco.com/motorcycle-multi-projector-led-headlight-w-brackets-dang/
It came with an H4 connection with an additional wire that I was told was for the running light. It came with no installation instructions or wiring diagram so I tried just winging it and haven't gotten it working. The stock wiring had 2 H4 connectors the first having what I believe was a ground (black) and then the low beam/running light (black w/ green stripe) and then the second H4 having a ground (black) the high beam (black w/ yellow stripe) and then a green wire (no idea what it goes too).
I want to wire it so it's just one h4 and I don't have all of this extra stuff hanging around.
I guess something to note is that my taillight and flashers were working before I tried this out and now they are not and I only get about 5mv to the low/high beam connections with the bike running so I may have jacked something up... the fuses were good but I'm not sure how to test a relay and also not sure which relay is for the headlights cause there are 2 identical ones adjacent to each other. Any help would be awesome and really appreciated. This is my first project bike so I'm learning as I go.
