Re: To Anyone Who Needs A Clutch Slave Arm
Right folks,
There is no need for hostility, rudenss or anyone taking umbrage over posts in this thread.
Its always hard to read someones intent from mere words, jokes fall flat and throw away lines come back to haunt you.
I moderate this thread and if you all can't keep it nice, I will close it-PERIOD!
First and only warning!
Disregard .......
User
Baltimore
Cancel that, I apologize for stating that(and will modify my earlier post), it was another new guy that's trolling.
However, politeness IS appreciated... Thanks...
I responded how I did when you took me for someone else and forgot your own politeness policy.
User
Baltimore
Anyway, to anyone who is doing this mod, I also recommend you watch this too... [video=youtube_share;aQnMdOL09uY]https://youtu.be/aQnMdOL09uY[/video]
swedespeed
ILLINOIS
Anyway, back on topic. It's a little janky and not the prettiest, but I extended the stock FZ6 lever myself to see how it performs with the additional leverage. It is indeed easier to pull the clutch and there is more friction zone. Not night and day difference, but definitely noticeable. I probably extended it by about 10-15mm. Bent the cable guide too so there's no potential excessive cable wear. In other news, the FZ07 lever I ordered just shipped. To be honest though, my mod will probably hold up just fine, it's solid, so we'll see if I end up swapping again.
User
Baltimore
I give you major credit. That's great that you were able to improvise and achieve the desired results. It's looks a bit Mad Max, but I dig it! :thumbup:
Did you bend the hanger with my crude screwdriver through the loop and gingerly force it method?
swedespeed
ILLINOIS
ha yep didn't have any nylock nuts in that size...really just used what I had.
zixaq
Iowa City
Swapped mine out today and the clutch pull feels a lot better!
one minor question though: Did you have to replace the C-clip that holds the slave lever? Mine bent enough when getting it off that I'm not super confident in it anymore.
User
Baltimore
Before reinstalling it, bend it a little farther closed than it will be when it snaps in place. Should be good as new :rockon:
zixaq
Iowa City
Oh man. Rode to work today and it is an entirely different bike. This is easily the best $20 you can spend on a fizzer.
User
Baltimore
It's awesome to see how much this has caught on!
zixaq
Iowa City
I think it may have even miraculously fixed my weird clicky noise on hard acceleration that's been bugging the **** out of me for two years. Will continue testing at every available stoplight :p
User
Baltimore
Could that clicky noise be your chain? I had quite a loose chain for a while and when it would snatch upon hard throttle, it would briefly be somewhat clicky and just overall sloppy.
swedespeed
ILLINOIS
needle nose worked fine for me. I hammered the clip against the ground to flatten it out before putting it back on.
swedespeed
ILLINOIS
If anyone wants my FZ07 lever I still have it sealed in the bag. My homebrew mod is working great so I see no need to swap. $20 shipped, at your door in a few days.
EDIT: SOLD
