sinistro789
- Joined
- Mar 8, 2016
- Messages
- 6
- Reaction score
- 0
- Points
- 0
- Location
- Liverpool, United Kingdom
Hey there guys needing some help. I am attempting to straight pipe FZ6 S2 with Y pipe and cherry bombs / glasspacks so that it has optimal flow vs stock nd gives that real deep growl like F1
https://www.youtube.com/watch?v=uzDICX_sG8Y @ 2 mins
https://www.youtube.com/watch?v=pc2iRsrFgt4 SOUND OF FORMULA 1
https://www.youtube.com/watch?v=iSChyRtcVAE R6 DUAL CHERRYBOMB
I have drilled out baffles with the biggest drill bit that would fit, i would say certainly much better than stock when broken in, but not even close to some the nice ones like the GPR ghost and some custom made exhausts that i have seen.
I have seen videos of bikes which use just the simple straight pipes. Better breathing and somewhat improved sound , but makes it sound much too tinny for my liking
https://www.youtube.com/watch?v=D8b9f8TTXTs GPR ghost
https://www.youtube.com/watch?v=xSUfNuKjoCE - FZ6 WITH JUST 1 GLASS PACK
Which is when i thought of the mid sized CHERRYBOMBS or GLASSPACKS which will give it that real deep throaty growl and could potentially benifit a perfomance improvement w/ PCIII and tune
pe
ive seen loads of videos of custom systems that sound way better than many aftermarket kits. i think its much up to the Y attatchment and the shape where extra power can be gained
Figured that 12 inch or 9 inch glasspacks/cherrybomb would fit perfectly with a true Y pipe attachement leading up to it. possibly change the the
possible ideas?
was thinking of widening the pipe out from 1.75 inch to to 2.25 using a reducer adapter so that it would be wider opening for better breathig and perfomrmance
and then using another pair of wielded on reducers so that the cut tips can fit out of the stock cover (back to 1.75 inch) , similar to stock outlets but wider. then to secure it was planning to use the stock fittings from the original exhaust and some springs for any additional vibration dampening .
was more or less planning to use this essential idea used phrank2k11 https://www.youtube.com/watch?v=YApdvcg0uU8
but the stock shroud fitting is essential
anybody on here done this mod before or similar ? just wondering know what the best measurements might be for this project?
Any help or advice would be greatly appreciated on this 1
cant wait to get this thing breathing fire
pe
possible ideas?
