vision's FZ6 streetfighter
test fitting
It looks like the best looking streetfighter Fz6 i've ever seen.
Without headlight.
What type of headlight are you planning to put on?
Without headlight.
Also - did you use the link on the swing arm??? If so anything you care to share there? Pictures etc?
Tks
thanks for the kind words guys, this project has been a LONG time coming :thumbup: will post pics of the suspension/subframe details when i tear it all down again for final assembly, still have LOTS to do before then
working on some headlight brackets. will probably redo them to angle lower
yes, i know its crooked. just test fitting still
tore it down again. all this just to unplug the ignition wires for relocation :/
im thinking about putting it here, not sure yet. space is really limited
printed new brackets for the headlight. if these work out they'll be in my next batch of parts to make in carbon fiber, along with a piece for the ignition and a bunch of various mounting tabs under the seat for my power commander, relays etc
also i snapped some pics of the shock mount since some people were asking on both forums.
jtarkany in socal helped me (did all the hard work) a few years back
flipped the brackets this morning before work. i think this is what im gonna go with, still haven't figured out exact placement just yet...
stem drilled and tapped, for some extra piece of mind
hit the steering bumps with an angle grinder and then filed em down zen status.
next i'll remove the ignition mounting from the upper triple and paint em both black. gonna have a buddy machine me a nice centering spacer for this area
here is how she sits now, some days it doesn't even resemble a motorcycle :(
hi you have done a great job so for bike look boss iv done this r1 fork mod myself just finishing it I used a shim on the bottom yoke and pressed it in to take up the slack wish I had drilled and bolted it like you now playing on my mind / found it to be quite tricky altering ignition barrel and steering lock /I have renthals fitted to my top yoke with same clamps as you but the spacing is wrong need to do something with that asap looking forward to more pics as I said great work so far mike.:thumbup:
AAAHHH, I'm so jealous. :<
I've had the swingarm, brake, suspension, and headers for this swap for over a year, I just don't have the tools to build the new subframe. I am le sad.
Everything looks amazing though, awesome job! :thumbup:
Subframe was built with only normal cheap garage tools... A Circular saw, angle grinder, budget drill press & patience. YOU CAN DO IT :cheer: :cheer:
Hey, if you need more space under the seat, look at the S2 Coolant Reservoir and placing it under the the header in front of the block. It will free up some space. Just a thought....
So, if you can tolerate a little black behind the headers, that may be an option. item 38 and 44.
FROM: http://www.600riders.com/forum/fz6-technical/50116-2007-fz6-parts-reference-diagram-images-x46.html
You're a genius! If it comes down to it I'll toss the old res & mount I made in the trash... Gettin hard to put things under my non-existent seat :Flash:
