- Joined
- Jul 30, 2007
- Messages
- 5,442
- Reaction score
- 99
- Points
- 48
- Location
- Adelaide,South Australia
Thought I better update on how I,m going with my XJR.
Firstly, I kept my speedo healer and gear indicator off my FZ6 as the XJR uses the same loom.
Installed the healer and hid the box under the right side cover.
Installed the gear indicator between the gauges, perfect spot for it, but hard to install there as the wires come out the bottom of the unit, so I removed the headlight and gauge pods , cut a slot to slide the wires into and glued the display down. I,m very happy with the result :thumbup:
then I installed a projecta battery tender and ran the wires to just under the tail piece and cable tied to the frame.
Then time for some luggage, I was going to use a ventura rack and fit a Shad box to it, but ventura now have an all in one kit that worked out a lot cheaper, though the box is smaller, I will see how it goes and may install a larger box in the future.
Then my alarm was installed and seems to work well.
Thats all for now, but far from the end
