My fan had tripped on @ 200deg reliably since I got the bike. This is a list I didn't want to be on but here we go.
Fan isn't obstructed.
Fuse tests good.
Coolant level is 75% at the reservoir (changed last year.)
So does that mean you saw the temp upwards of 215 and no fan came on?
There is a relay that could be suspect still and of course disconnecting the fan and jumping it with straight 12v off the battery is fair test to confirm its OK.
IIRC mine comes on around 204F. Let it sit and idle till it hits 210 and have your gear ready for a quick spin or just shut it off.
One option is to test the relay and also with the relay removed test the bikes harness. Both are possible...
Thanks Randy. I removed the plastic guard and topped up the coolant then idled it to 210F where it finally spun up.
Unless I'm going crazy it's just changed its behavior. The fan is now coming on right at 210F and shutting off at 199F. I'm glad that's all it was.
^^ Likely true (getting old & going crazy)... Just chill and have some Pie! I know that works for me! Blah
I was thinking about an import (VW Scirocco) that I owned a number of years back when I had trouble with the fan sensor that would act up and not trigger the fan startup. After replacing the sensor a couple of times I ending up running the switch wires to the relay through the firewall so I could start the fan manually if need be. So I have been looking through the SM, but did not see anything. I searched Partzilla and found a poor diagram that identified a thermosenser maybe located on the backside of the engine. Does this start the fan or I am missing another sensor in the cooling system?
Quick question, are you guys seeing your actual temps on your dash ? Or you know that 4 bars is 210, and fan should be coming on,
