Eldberg
Have looked up the procedure for changing coolant in the shop manual. Is there anything special I should think of? Looks difficult to get the reservoir out so it can be emptied...
Åke
Åke
Åke
Get yourself a new copper washer for the coolant drain bolt! Mine dripped until I changed the washer after my coolant change.
This man speaks the truth. Changed the coolant over the weekend and there's a slow drip. Sucks to waste a jug of coolant for a ten cent part.
I did not know this. I did mine this past weekend, and no drips so far.:cheer:
If you keep the radiator cap on, and borrow another's finger (the proverbial finger into the leaking dam), you should be able to swap out the washer without loosing maybe 1/2 cup of coolant..
With the radiator cap off, that thing will piss like a race horse...:thumbup:
A slight dab of sealer on the washer/threads wouldn't hurt either.
Just an FYI. Being its a thin copper washer, you can, with a very fine, flat file, give it a quick cleaning up and make it smooth again. I still have the original coolant drain washer and have changed my coolant at least 3 times since I've owned it, same washer.
I do this as well for the oil drain washer (I pitched the stock washer) and replaced it with a COPPER, automotive washer that's re-usable..
You can find copper washer packs for cheap on Ebay. Pretty sure it's 6mm ID that we need for that coolant drain bolt.
M6 6mm Crush Copper Washers Quantity 10 Pieces | eBay
Wouldn't hurt to measure it before you order though.
Along the same lines as this thread, but I just got my bike back from the repairer (after an unfortunate lowside) and whilst it was there, I got them to do a 40000km service.
I noticed when looking at the consumables receipt, they used Motul Inugel Extra coolant. A quick google shows that is a car coolant.
Now, please forgive my memory, but I remember something about the particle size in some coolants (or something) is abrasive to the water pump, but after a quick search, I can't find it.
Can someone please remind me of of specific nature of this coolant, so I can check whether they've used the wrong type? (I remember because the Tectaloy Extra Cool I use in my car is incompatible)
Cheers,
Rick
P.S. The repairer is a Kawasaki dealer, so if this Motul Inugel is incompatible, please supply a source/service manual reference, so I can go back in and tell them....
Cheers,
Rick
