seneca
Hi there, nice to be the first post in this sub-forum. As you are aware we have a deep economical bad momentum in Spain. Find below an original anti-crisis post. I posted it at Fazer-hispania but thought it was a good idea to post here too.
Hi all,
great home gadgets, found one that gave me very good result:
Guard to grease chains, HighTech by Seneca ...
materials required:
1 Bottle of Nestea (empty), Coca Cola OK as well.
1 Cutter (take care with your fingers)
Making of:
1 drink the contents (if not empty)
2 Make a cut with the Cutter to remove a band corresponding to 1/4 of the bottle logitudinal section (see photos)
3 Make a recess in the bottom of the bottle about the same size approx. section of the chain
application:
1 Place the bottle in a longitudinal direction, wrapping the string in the section that goes under the swingarm (between pinion and crown) leaving the opening three quarters up, fit the chain in the recess at the bottom of the bottle.
2 Grease without fear, nothing but nothing escapes .... In addition, its fixed and allows the lubricated chain to move freely.
3 Remove, clean paper and ready for the next.
In the photos you can see how it looks after greasing
Uploaded with ImageShack.us
If the same has already been posted then I'm doing something dumb.
greetings
Hi all,
materials required:
Making of:
application:
greetings
