klajdidervishi
hi,
i have a problem with my neutral light.
when the gear is in neutral the lamp don't light.
please help...
please help...
thnx alot.As you are from Albania, I'm guessing your bike is fitted with the factory immobiliser, as are all others sold in the UK, EU and AUS markets.
After looking at the wiring diagram for the FZ6 NHG (Non US, Naked Model, 96HP), it seems that the only 'minor' fuse likely to effect the operation of the neutral light circuit is the Backup fuse, this can be found within the fuse box behind the throttle side, side pod.
However, there is no need to check it directly, as this fuse involves the power supply that allows your clock and trip meter values to be maintained when the ignition is switched off. Are your clock and trip meters resetting after the ignition is switched off?
It is also common to have issues with the neutral light after washing your bike or riding in the rain, have you done either recently?
Hope this helps,
Yamahaboyz
hi,As an automotive engineer, I definitely wouldn't recommend the replacement of parts at random as an effective solution to solving problems, as this tends to become unnecessarily costly and wastes time.
Personally I think that the problem is likely to be very simple, most likely to be related to some of the things mentioned in my previous post, or something just as simple.
By all means have a good look through the owners manual to familiarise yourself with your bike, the service manuals are also available somewhere on the forum if you wish to go more in depth, I'll insert the link if I'm able to find it.
Yamahaboyz
Edit: Can't seem to find a link to the Australian Service Manual (Which I believe covers all European Models aswell), the US one can be downloaded here though: Boneman's FZ6 Site - Mods
hi,
thnx for the advice Yamaha Boyz
my bike before is an accidented FZ6 (S)
i convert it in a FZ6 (N)
i buy the gauge and some front parts.
the gauge didn't work than i replace the main wire
with the main wire that i replace the gauge don't work again
all the fuses are ok
i haven't seen the clock and the trip meter because i didn't ride recently (from the weather)
i have a kick stand sensor in my bike
When i turn on my bike the kick stand should be close because the bike don't turn on.
can u help with some steps because my mechanic don't now what to do.
thnx a lot again
thnx Motogiro
but i think the problem is somewhere else.
thnx a lot
Thnx,
yamahaboyz,
the bike run very well but the neutral light on the tachometer don't work.
i don't know the reason.
help me
hi
the wire till to the neutral switch its ok
1) Bike in neutral, starts without pulling the clutch. (don't start)
2) Bike in gear, doesn't start without pulling the clutch. (don't start)
3) Bike in gear, starts with the clutch pulled. (yes it start)
4) Kickstand down, bike starts in neutral. (don't start)
5) Kickstand down, bike doesn't start in gear. (don't start)
thnx in advance
hi
thnx in advance
Does the wire, when grounded, illuminate the green light with the ignition turned on?
I'm trying rule in or rule out the mechanical switch.........
Ok, this has basically confirmed that the ECU is not being 'told' that the bike is in neutral, as in neutral the bike should start without the clutch being pulled in.
This is absolutely the next thing to do, ground the wire and see whether the neutral light illuminates, if it does, the neutral switch is very likely to be the culprit, but a fault in the activation of the switch is also a possibility.
Yamahaboyz
thnx a lot all of you
i need to know "the interrupt module has a toasted diode"
what is this???
thnx
Hi boys,
The problem was the neutral switch.
I replace it with an used one and everything is perfect.
Thnx a lot to you all.
See you if anything go wrong again.
Hope NOT.... ;-)
