chunkygoat
Welllllllllll I'm pretty sure I destroyed my front sprocket and chain. I posted a couple of weeks back about chain tension when replacing the chain and sprockets.
Well I misunderstood and gave about 1 and 1/2" slack.....except it was LIFTED on its centerstand. I thought nothing of it until I felt some slippage and noticed some small little metal specks around the rear wheel and along the chain.
By then the damage was done - I'm sure. The chain seemed to get looser on me over the next week and I had re-tightened it - but it did no good, the damage was already done.
I know my mistake, I simply had too much tension on the chain, it stretched as a result, and became loose - and began grinding the front sprocket away.
SO - if you are a DIY wrencher and you plan on putting on sprockets and a chain - DO NOT OVERTIGHTEN. Take the bike down off the centerstand then check to maintain the 1 and 1/2" slack. Or else you will end up like me -> out 150$.
Well you live you learn, hopefully somebody else can learn from my basic mistake.
Has anybody else had something to this effect happen to them before? Is there anything else I should be made aware of or inspect for damage beyond just the sprocket and chain? Just briefly looking it over, I don't see any damage so I'm hoping for the best.
