Pass Switch Stuck
Beerdrinker
2^57885161-1
Lisbon
Hello,
The pass switch of my FZ6S 2006 is stuck inside. Someone can tell me if it can be fixed?
It dont move neither in or out.
Do you know if I disasemble the Left handlebar switches it can be fixed from the inside or it is sealed?
Thank you for the help!
Hello,
You should be able to get to the pass switch inside the handlebar switch.
Opening the handlebar switch should only take a couple of screws, to get the parts separated.
Once done, have a look at what might have caused your problem :)
Grtz,
Degake
Thank you for your answer!
I will try to fix it.
I'm a bit scared, after all she is "my precious"!! :beer:
Done!
I was complicating a simple issue.
just remove the two screws in the handlebar switch.
open it with careful
inside, remove one screw and a little piece of metal that hold the cables in place
remove one screw that hold's the pass switch.
the button was superimposed (??) maybe some blow in the top of it.
mount everything back together and drink 3 beers. :beer:
DONE!
