badweatherbiker
not foamy milky like a coolant leak but clearish bright yellow, never seen anything like it before. I is supposed to be fresh but I think I may change it out anyway. what do you guys think?
Sent an email out to the dealership that the previous owner purchased the bike from since they did the oil change.
I was curious because it doesnt feel very slick and its very thin.
Yep, it was changed back in August and only 150 miles have been put on it since. I bought some oil and a filter yesterday and hopefully Ill get ti changed in the next few days. Ill try and snap a pic of it but it doesnt look like any oil I have ever used.
Do these bikes come with some sort of quick change drain plug or something? There is a big knob where the drain plug is.
And i assume the filters are the samy through all fz6 years? I bought one that was listed on a search result for a 2007 model for my 2004.
Thanks!
KEN
Before you drain it, is it over-full when on center stand and kiss the threads to case? Any chance someone added something that didn't belong? You know, the mischief kind??? Hopefully not.
Ditto - I'd dump 3.5 qts of cheap dyno oil in it and ride it for 20+ miles. Dump it. Then replace that with what ever you intend to run.
I've seen old automatic transmission fluid turn yellow from varnish, but never engine oil.
3 quarts. 3.5 would over fill
This may be a crazy question, but how much fresh oil have you seen? It's pretty much always yellow.
And when you change the oil, all of it is not sitting in the gallery. A good bit stays in the transmission and pump mechanism.
