pod light install problem
jerdman89
wait... what goes here?
Carlisle, Pennsylvania
ok well I ordered a pod light kit on ebay and tried to get it installed today. I dremeled out the hole and when I checked the fit I got the led caught and it came out of the socket and fell down inside the headlight housing. So basically how screwd am I and how hard is it going to be to get it out of there. The yellowish green thing is the led bulb.
Chew up some gum, then put it on the end of a piece of metal coathanger bent to go inside the headlamp unit. Get the gum to stick to the bulb and then pull it up and out.
the led bulb is bigger than the gap between the lens and the reflector so if the gum trick dont work I guess I'll be heating up the oven tomarrow. One of the simplest mods ever just turned into one of the most difficult.
A small, strong magnet on a decent nylon thread or string. It should stick to the LED leads.....
Sorry about the tape and like Krid80 said pull the headlamp out for better access.
Take your time now and do a good job! Hahaha!:Flip:
Probably zero iron in the LED leads...... copper and aluminum won't stick to a magnet. Neither does lead. :rolleyes:
I ended up taking the whole front fairing off and just dumped it out the way it went in. while I had it off I finished the install. Thanks boneman for taking pictures and posting them when you installed your projectors, made things alittle easier on me. It wasn't as hard as I thought it was going to be.
