Nice write up and looks great. Not overdone and the nice understated glow that is really the mark of a good install.
You said you used the constant power source. Did you waire directly to the battery?
I can't tell you how many times I have used your site to help with a mod. Keep up the great work.
Thank you!
I wired the 12VDC + to an existing constant 12VDC+ wire I ran to the wiring for my Acumen DGV unit - and it came from a fused 12VDC+ off my battery to my Stebel Horn relay.
So yes, it a round about way it is directly from the battery, just make sure you put in an inline fuse to anything electronic you add.
BATTERY+ >>>>>>INLINE FUSE>>>>>ELECTRONICS (+)
If I originally knew I was going to do this many electrical mods, I would of seriousl considered wiring in a fused + terminal block and a - terminal block and centrally locate them under the tank. Then every time you need to wire in a new electrical mod, you already have a fused power source and a ground source and everything comes back to one point. Easy to install, troubleshoot, change and remove electrical mods.
