Hydraulic clutch?
04fizzer
Fairport, NY
Part I:
Does anyone know of a hydraulic clutch kit for the FZ6?
Part II:
What year R6 is the FZ6 motor from? That may broaden my search.
Part III:
I'm thinking about a hydraulic clutch because I get severe wrist pains when I have to shift a lot. I'll most likely try a new clutch cable, and adjusting my bars and levers around first, but wondering what kind of options I may have in the hydraulic world IF the cheap route doesn't work.
huxy
cambridge
Have you tried lubricating the clutch cable? I noticed a big difference when I did mine and it only cost a couple of quid for the lube tool off eBay and a can of WD40 I already had in the garage. Cheap and cheerful and very effective.
04fizzer
Fairport, NY
I have tried that, with actual cable lube, and still no dice.
I've done the same. The clutch cable set-up is the worst I've ever used. I would love a hydraulic option but there may be be another mechanical solution because I was trying the clutch on a GSXR 750 (cable) the other day and they're like butter!
DefyInertia
Former '04 FZ6 Rider
San Francisco, CA
Have you used a lot of hydraulic motorcycle clutches before? In my experience they are not a ton easier to pull...just better action.
What kind of riding conditions are causing you to shift so much? There may be an easier solution.
EDIT - or you can extend the slave lever arm killernoodle style. Probably a lot cheaper and easier.
chemicalsmile
Omaha
Well this thread started way better than the one you started on SBN :eek:
I have a feeling that the new Gladius owners are going to make the gixxer :squid:'s look smart
