Broken valve stem. Is this an easy fix?
Truthalive7
Texas
I'm thinking you have to break the bead on the tire, pull out the old one and insert the new one from the inside of the rim . I would say the wheel with prolly have to come off.
RJ2112
Dahlgren, VA/USA
www.etsy.com
Anybody know what size valve stem to buy? Thanks
If you plan on taking the tire off the rim yourself, I'd go to the local MC shop, and buy one from them...... I believe the stems are a standard size....
One of the things you might want to consider, is installing a stem with a 90° bend to it, so the schraeder valve points out sideways. That can make checking the pressure a lot less fiddly.
Alternate solution
Falcon1220
Vancouver Canada
You can probably figure it out by looking at this site based on your year of the bike. Look up the part number and do a search on it to get additional information.
PartShark.com --- Motorcycle Parts, Accessories, Apparel, & Merchandise.
Alternate solution
:cheer:
Man I love this forum. I learned two new things in these replies.
Thanks
bd43
Alberta, Canada (GMT-7)
Alternate solution
This shop may no longer be shipping due to a death in their organization.
You may want to try this place...
KurveyGirl - Motorcycle Stuff: Dzus Fasteners, angled valve stems, Vesrah and More
There are two sizes, 11.3mm and the 8.3mm. According to the website, it looks like the 11.3mm is for the Yamaha bikes.
jacobdahl
Burnstown
If you decide to just pop the bead on one side and stuff a new valve in the hole (which is the lazy/easy way to do it) make sure any bits of the old valve are not left inside the tire, as they can damage the tire from the inside, and will also make an annoying noise. The best way to deal with it is to remove the wheel and take the whole assembly to a tire shop with a proper bead breaker. The shop I work in would not charge more than 5 bucks to do a simple job like that, and you know the tire and rim won't be damaged because we have the porper tools to do the job.
08fz6
Make no excuses!
Central New york
something like that my dad usually says dont worry about paying just remember us when its time to get tires.:thumbup:
