yanek
Hi i have for sale Car Subwoofer. I did it by myself, after calculated all sizes for boxes. I sold my lovely BMW last year and i left it in the garage,but now i am doing clean up, so it is for sale. I have Original boxes for amplifier and speakers. Also i will provide high AMP wires with fuse 80A. Ready to install to car.
1. Hifonics BXi 12100
Brutus BXI Single-Channel Monoblock Super-D Class Car Amplifier
RMS Power Rating:
4 ohms: 450 watts x 1 chan.
2 ohms: 900 watts x 1 chan.
1 ohm: 1200 watts x 1 chan.
MOSFET Power supply
Super D-Class amplifier relies on a super-speed enhanced chip-set to produce higher current capacities and more precise digital to analog conversions
Wired remote bass level control included
Power and Protection LED indicators
Built-in system diagnostics offer protection of DC, Speaker short, terminal, and overload
Tuned Bass EQ (0-10 dB bass boost at 45 Hz)
Dampening factor: >250
Single-channel monoblock channel operation
1-Ohm stable
Phase shift: 0-180 degrees
Preamp RCA outputs
Input level control: 0.04V - 18V
Balanced line input for MX accessories and line drivers
Heavy duty aluminum alloy heatsink for extreme heat dissipation
RCA level inputs
Screw terminals
Variable low-pass filter (35-250 Hz, 24 dB/octave)
Subsonic Filter (15-35 Hz at 24 dB)
Frequency response: 35-250 Hz
Dimensions: 11-1/2"L x 9-1/2"W x 2-1/2"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
2.
2 X Rockford Fosgate Punch P3D412
12" Dual 4 Ohm Rockford Fosgate Punch Series Subwoofer
Power Handling:
Peak: 1000 watts
RMS: 500 watts
Impedance: Dual 4 ohm
Kevlar Fiber reinforced semi-pressed paper cone
High excursion Poly-ether-ester surround
ABS/Acrylic dustcap assembly
Tear and fatigue resistant poly-cotton dual linear spider
Embedded 16AWG tinsel leads
Venturi-Effect cooling increases air speed across key thermal components of the speakers motor parts to maximize cooling
Reverse mountable subwoofer with reversible diamond cut cast aluminum trim ring
Tall profile surround allows maximum linear travel without reducing overall piston size
Extended pole piece and bumped backplate
2.5" High temp 4-layer voice coil with spun-laced Nomex® reinforced collar
Anodized aluminum voice coil former quickly dissipates thermal build-up on the voice coil
102 oz. double stacked ferrite magnets
Protective PVC textured magnet cover
Dual 10AWG compression speaker connectors
Frequency response: 27-250 Hz
Sensitivity: 85 dB
CEA-2031 Compliant
3. Stinger SPC122 Capacitor
Digital 1 Farad Capacitor
True 1 farad capacitor for systems up to 1000 watts
Bright blue LED voltage display
Minimizes Headlight dimming
Louder and clearer bass response
Stabalizes battery voltage
Uses ring terminals for use with any gauge of power/ground cable
Includes mounting hardware for a secure installation
Color: Chrome
Dimensions: 10-1/2"W x 3"D x 3"H
Price: $ 250
Local Pick up ( it is heavy) NYC, NJ area.
