08 FZ6 Dual headlight kit -where to buy?
DarthDad
Central CA
I been reading the threads on the dual headlight mod. I see there was a kit sold. I am looking to see where I can buy that kit?
I was seeing if there was a list of parts that I would need if there was a wayto have both lights low/high beam? I saw some you tube videos.
Thanks for all the help.
There was a "BD43" kit made quite awhile ago.
It basically runs one wire from the starboard (right) side of the un-used headlight bulb terminal to
a harness connector under the battery tray... That harness plug is also unused.
I don't have a picture of that harness and the terminal where it would attach.
Someone here will likely post a pic of the location. You would only need two terminals
(head light and the harness plug) along with wire to make your own. There would be NO
cutting/hacking up the harness/wiring..
A quick search shows the original thread from the designer along with spec's:
DarthDad
Central CA
thank you. I did a search and it looks like he has not been on in a while. :( I don’t do well with soldering.:)
The harness, under the battery box takes the small, thin terminals (see below).
If using other connectors, you'll be hacking up the harness to plug in.
From the very FIRST POST (might want to read it):
