Fuel Grade (regular, mid-range or premium)
Fuel Grade
  • Regular
    Votes: 397 44.1%
  • Mid-range
    Votes: 68 7.5%
  • Premium
    Votes: 436 48.4%
  • Total voters
    901
tcmalker
Banned
Chicago
dont' wait your money on anything but a regular. But from what I've heard, avoid the ethanol BS as it reduces your mpg. Hard to avoid it though, it's EVERYWHERE!
chuckfz6ryder
Lakeville MA
I've never had a problem with regular (87 octane). We have ethanol in our gas in MA, for winter storage we have to use the blue STABIL for ethanol.
Erci
Howie Mandel's evil twin
Pittsford, VT
Zero benefit to running anything, but regular, but many swear that they feel difference with premium. This has been covered several times.. replies are same every time too :)
FIZZER6
The Angry Blue Mantis
Virginia
I switched to premium 2 years ago and felt a huge difference in engine smoothness in the infamous FZ6 "buzz range" between 6K and 7K rpms. My mechanical engineering mind tells me that this is likely due to the fact that higher octane is less volatile and probably ignites just a few milliseconds later than 87 octane resulting in a smoother power band...even if I'm loosing 0.5 hp.
My father is a chemical engineer for a major oil company and there is more to "Premium fuel" than the octane rating. Premium fuel's from Shell, Exxon and BP have the maximum additive package which includes detergents that keep your engine and fuel system clean...it's not just hype...Premium has significantly more cleaning agents.
Also the higher the fuel price, the better value premium become since it's always only about 25 cents/gallon higher than regular...that's only $1 per tank in the FZ6...I'm getting 55mpg commuting...I think I can afford an extra $1 per week to have a smoother, cleaner running FZ6.
FloppyRunner
Motorcycle Noooooooooooob
Phoenix, AZ
I've been using premium simply because before I got a chance to check out my owner's manual I assumed any engine with a 12.4:1 compression (or whatever it is) would take premium... Then I saw the manual but I'm hesitant to "downgrade"... Eeehhhhh...
LERecords
Shelburne, VT
I have never used anything but premium.. i know that it doesnt make a difference, but i feel better about it.. dont think there is any difference, but i have never used anything else... and the bike is worth it :thumbup:
VEGASRIDER
100K Mile Member
RENO, NEVADA USA
59,000 miles on regular and still rolling!
If I spent an extra dollar per fillup using premium like others have been doing, I would have just thown $400 away. Yeah, a dollar isn't much, but it does add up. I did not notice any significant gain or loss using premium for mpg.
mrphotoman
Massive Member
PA
i am sure the manufacturer knows what fuel is best for the bike. unless you are running forced induction on your bike (turbo, nitrous, etc) you are wasting your $ with the premium fuel.
Now on my car, running a custom tune with a supercharger, smaller pulley (+4.5psi), meth and nitrous and slightly advanced timing I run premium with klotz when racing. that combo with the raised octane from the meth= a lot of fun.
gpostarmy
Michigan
I will generally run reg for two fills then one of premium. I do this because of the additives in this grade which help clean the system. Just my technique.
1.8tbora
Stealth FZ6
Troy, MO
I use regular, just because I bought the bike to save on gas and it would be stupid to spend more per gallon on gas when there is no gain. MPG's and FUN, that's what its about.
FloppyRunner
Phoenix, AZ
It's interesting to me that people say that the manufacturer would know best what fuel to use in their motorcycle, but I'd suspect that it's these same people who drop a bunch more money on fancy synthetic oil of whatever weight they prefer despite the fact that the manual simply calls for...whatever it calls for... Not trying to cut anybody down, just making observations...
AngelFZ
Cocoa, FL - USA
I started using premium when I bought the bike. After reading about not real benefits about it I started using regular.
Regarding MPG, I believe I lost some after changing the stock exhaust and it seems I lost some more after changing from premium to regular gas
dean owens
Hippopotomonstrosesquiped
pittsboro, nc (near raleigh)
www.ccf-unc.org
Regarding MPG, ... it seems I lost some ... after changing from premium to regular gas
what do you mean by seems? did you track your milage enough before and after to run the numbers? i'd be interested in how much you actually lost and if it's still a better buy with the cheaper gas. or if you save money by buying premium and getting better milage.
LERecords
Shelburne, VT
if its between 1-4 mpg of a gain or loss.. i accept that as the cost of having a bike.. some days im throttle heavy, some days not.. it would be worth tracking for the whole season (or 2 or 3) just to see what i average when im just going out and having fun vs taking the bike on a motocamp trip...
AngelFZ
Cocoa, FL - USA
The "seems" is precisely because I was not really tracking the miles.
I reset the tripmeter (A) counter to zero after every fill up but it is not fair to compare:
The stock bike would give me some 220-230 miles
Then I changed the exhaust and the numbers went to the 200+ range (with premium gas).
After changing to regular gas it went to the 200- range.
Keep in mind I'm not an aggressive rider but now I'm riding more agressibly than when I just got the bike (in terms of acceleration) so since the overall riding conditions (the bike and the way I'm riding now) have changed, it is nor fair to do a simple comparison.
