juggler
Hello,
I'm searching for help because I have difficulties with wiring of headlights. Yamaha FZ6-S 2005, used in Finland. I received a few month ago complete headlights from USA (bkmoto.com). Actually i quetioned seller because of my problem, but the seller would not be able to answer without seeing pictures of wiring. H1 mini projectors, dual low/high beams, angel eyes. Angel eyes are working perfectly when i start engine, but no low beam still. When i turn switch dual high beam goes on, when i switch back to dual low beam mode, nothing happends, only angel eyes are on. I double checked all wires, probably I missed something, but no, all wires are connected. One + wire with fuse goes straight to the battery. Two (-) ground wires connected under the fuel tank to the frame. I forgot to mention that i also have switch which turnes off low beam if i would like to ride only angel eyes are on; so if this switch is on, no low or high beam available, so the switch is working fine. The problem is why there no low beams at all?? Balasts are good, relayes working fine. Any ideas??
