fz6ns2rick
hi,
it was only the front sprocket that was worn in this manner, the sprocket was worn on the outer side (kerb facing not engine facing).it was a good 1/4mm deep and perfected matched the chain. the rear sprocket had the slightest wear but only to the teeth not to either side. the chain had a bad link which caused the initial clicking/tapping under my left foot. so i replaced both sprockets and the chain, i bought them together in a kit not seperately. i cleaned and lubed ,greased ,and torqued everything as per manufacturers instructions being careful to hold this to the letter. i gently rode the bike for the first 50 or so miles and then went back to normal riding (nothing harsh).
it did not bang or slip or clunk into being quiet, it just stopped. i gave the bike an oil and filter change just less than a month ago, all levels were correct at time and at subsequent checks after. it looks clean and free from debris on the change over.
it changes gear ok , the obvious clunk into first and then from first to second, but after that fine.
the only thing i find wrong now is the clutch whine which is nowhere near as bad as the whine i had from the thing before. but i would like to get rid of that too if possible.and the weird spin out of the clutch when i rev with the clutch depressed in first or second whilst coasting. dont have a clue what that is , feels like when on a push bike coasting and then you go to peddle but nothing happen for a sec and then you feel the rear sprocket catch on itself to start pushing the bike forward.
other than those two little things the bike goes really well and handles lovely.
took me a little to do the string alignment thing but i have it down now. spare bricks to hold the string and im away .:thumbup:
so other than what i have told you all i have no idea (as youve probably guessed).
but again thanks for the info and really quick responses, and if anyone does know what the whine is on the clutch or what to do about the catch up thing then please let me know , i will always listen to advice from this forum as your all well up on this.
