'07 FZ6:Scorpio anti-hijack?
Tailgate
Sacramento, CA
Do you have Scorpio anti-hijack wired in? If so, could you tell me which wire (color) and where the anti-hijack wire is tapped into on your '07 FZ6?. If I can benefit from somebody's else's research/work this would be nice. I know SBN has a thread on this but it's still not entirely clear to me.
Well, I'll answer myself since nobody else is on track here. Scorpio recommends tapping into the "vehicle down" sensor, which on an '07 FZ6 is on the right side. It's hanging on a rubber grommet from a metal tab. You must remove the right-side rear cover to access it. It has the word "UP" imprinted on the black module and there are three wires going to it. You tap into the light blue wire with the anti-hijack. wires. Hopes this helps out somebody, sometime! This location seems to be the least invasive for utilizing the anti-hijack module.
