C
CoolATIGuy
So I'm trying to loosen the rear axle nut, but having trouble. Using the wrenches in the tool kit and two ~2' long steel pipes as cheater bars, one on each side.
The nut spins easily, but spins the bolt head on the other side of the bike at the same time. If the other side is held in place while trying to loosen the nut, it's incredibly tight. Using force I can get it tightened/loosened to some degree, but it just gets so tight even the steel cheater bars aren't working that well (and wrench is getting bent out of shape).
Also, when tightening the axle back up, it pulls the right side of the axle backwards, and the plate on the back of the swingarm pulls away leaving a gap - how does one combat this? A knee against the tire isn't enough.
Thanks in advance!
Thanks in advance!
